Problem with Converter Mathcad Prime 4.0
sundoopi
8-Gravel
Hello erverybody,
I want to open a *.xmcd-file (which created by Mathcad 15) in Mathcad Prime 5.0, but failure. PTC Mathcad Prime 5.0.0.0 XMCD, MCD Converter can not convert too: error message is "Mathcad 15 M010 or higher is required to run the converter.".
And after each converting, I must restart the converter. Is it normal?
I used the data in xmcd converter as exercise, but converting was also fail.
Could you tell me what are the reasons for the two question above? Thanks for your antworts.
Best regards
Sun
LucMeekes
(To:sundoopi)
The error message is clear. You HAVE to have Mathcad 15 Installed on the same machine. With the same license of Prime you can also install and license Mathcad 15. Present edition is M050.
After installation conversion should be possible.
LucMeekes
(To:sundoopi)
LucMeekes
(To:LucMeekes)
Yes! Thank you Luc!
Sorry, I thought the converter could run without MC15. Cat Sad
After MC15 was installed, all problems are solved. Thanks again.
BR
Sun
