Hey! Im having big problems with the addition. In the first picture you can se how 1/alpha is added to 2/lambda without 1/alhpa being under the division. This is my problem I'm trying to recreate it but nothing works. The second Picture is how i manage.
Type the following:
1m^3<space><space><space>/1/a<ctrl-g><space><space>+D<ctrl-g>x[i<space><space>/2<space><space>/l<ctrl-g>
Thanks for the fast reply! I tried do as you say but in that case 1/alpha is added to entire x1/2/lambda wich is not what i want.. 😕
Compare pic 1 to pic 3 i Believe youll see what i mean
Type the following:
Thank you sooooo much!!!!!!!!
