Hi everyone
Mathcad Prime is new to me, so there might be a simple solution to this problem.
I'm trying to use the find-function, but it give me an error I don't understand; 'This variable is undefined. Check that the label is set correctly'
I've even tried with an example used in the help-function. I've attached a screen- dump of my problem.
I get this message no matter which function i need to solve, what am I doing wrong here?
As far as I can tell, you haven't defined a "solve block". Click on the "solve block" button on the Math ribbon, this should create a solve block into which you should re-enter your expressions. I've only got Prime Express, which doesn't have solve blocks so I can't give you an example.
Look up "Solve Block" in Help.
Stuart
Could you please post your worksheet (or a worksheet showing the problem). Some problems are not readily discernible from a picture, particularly if they involve implicit multiplication, labelling or indices/subscripts.
Stuart
Stuart
Great - thank you!
A bit different from MathCad 12/13/14, but I like it! ![]()
Jonas
