Pucher Charts (Plate Internal Forces) In Mathcad
Hi all,
I have just started using Pucher charts to compute internal forces (specifically moments) in plate elements. While the charts are very easy to use once you've understood how they work, it can be tedious to use them over an over, especially if iterations are necessary. I read through the book by Aloph Pucher to try and understand how the influence surface contour plots were generated, but I was unable to find that information. I was wondering if anyone else here has used the plots and knows if they can be generated in mathcad (or any other mathematics based application) with finer intervals. I'm trying to see if the plots are based on solutions to the differentiation of the deflection surface or through some emperical method. I'm hoping that if the plots are created mathematically, it could be possible to use mathematics capability of mathcad (or mathematica) to compute moments by integrating over the loaded areas.
I hope I'm making sense. As I said I've just started using this method so please point out any flaws in my understanding.
Any and all help is appreciated in advance,
Bests,
Ali
