How to convert rpm to m/s in prime 7.0? I have velocity of 125rpm for radius 0.32 m how do I convert this to m/s
You cannot convert these.
However, the speed of a vehicle driven by a circular wheel with radius 0.32 m cycling at 125 rpm can be calculated:
Just multiply the circumference of that wheel with the number of revolutions per unit of time it makes.
even though a direct conversion is not possible as these are two different kinetic properties, you can calculate the circumferential velocity; see attached sheet in MCP 9
Hmm,
in Prime rpm is different from 1/min.
Hello Martin,
thank you for bringing it to my attention. That does make a difference
regards
Raiko
https://community.ptc.com/t5/Mathcad/rpm-frequency-unit/td-p/285769
There are two types of dashboards of cars:
