RPM to m/s
BT_10780541
6-Contributor
RPM to m/s
How to convert rpm to m/s in prime 7.0? I have velocity of 125rpm for radius 0.32 m how do I convert this to m/s
5 REPLIES 5
LucMeekes
(To:BT_10780541)
You cannot convert these.
However, the speed of a vehicle driven by a circular wheel with radius 0.32 m cycling at 125 rpm can be calculated:
Just multiply the circumference of that wheel with the number of revolutions per unit of time it makes.
Raiko
(To:BT_10780541)
even though a direct conversion is not possible as these are two different kinetic properties, you can calculate the circumferential velocity; see attached sheet in MCP 9
LucMeekes
(To:Raiko)
Hmm,
in Prime rpm is different from 1/min.
Raiko
(To:LucMeekes)
Hello Martin,
thank you for bringing it to my attention. That does make a difference
regards
Raiko
https://community.ptc.com/t5/Mathcad/rpm-frequency-unit/td-p/285769
There are two types of dashboards of cars:
  • with rpm as radian per min for Mathcad users
  • with rpm as revolution per min for others normal people.
https://support.ptc.com/help/mathcad/r9.0/en/index.html#page/PTC_Mathcad_Help/frequency_and_angular_velocity_units.html
Martin Hanák
