Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
Dear all,
I use frequently mathcad for data analysis. The data are stored in a specific, known folder. The data are generated from another application and the filenames change, depending on the acquisition conditions. I need to check by hand the filenames and then put them in an array, which mathcad uses to read the data.
Can someone tell me how to get from within mathcad the filenames of all files in a specific folder and generate an array comprising these filenames
Thank you
Will the attached help?
You can change the path of the second component to your desired folder and this should display your files.
Mike
Mike
See my collected utilities http://communities.ptc.com/docs/DOC-1612
It is also available in V11 format.
It has lots of these types of utilities. They are mostly collated from the collaboratory, but a few are my own 'improvements' (bending to my particular needs <wink>)
Philip
Thank you Philip and Mike
Hello Philip
Can you give me your collected utilities in V11 or V12 format ?
Cordially
Eric
Here is the link ("Component Utilities2011.mcd (V11)"): http://communities.ptc.com/docs/DOC-1613
Many thanks to Vladimir
You're welcome.
There is a large collection of scripted components (including the one that gives lists of files) here:
Many thanks to Richard
