8-Gravel
August 15, 2023
Regarding Mathcad automation using API / .NET
  • August 15, 2023
  • 2 replies
  • 1000 views
Hi  - I am exploring the possibility of having the calculation logic in Mathcad file, and then having the .NET web app take the user inputs and then sends the input values to a Mathcad file running on the server, and then get back the calculation outputs from Mathcad - which will be displayed on the web app.
- Does the Mathcad API support the above scenario? I tried to check this link - Getting Started with the PTC Mathcad API | PTC | Mathcad - But it is not opening for me in either Chrome or Edge.
- When Mathcad is called, will the Mathcad run in the background - or for ex; in case of a .NET desktop app which is using Mathcad installed on that desktop,  can the user see the Mathcad window - when it is being called from the .NET code ?
Regards
Vijay
Hi Viujay,
Look at help as a start in API programming.
VijayN8-GravelAuthor
8-Gravel
September 27, 2023
I checked and found that the link - https://www.mathcad.com/en/blogs/getting-started-mathcad-api - is now opening. I will check this.
Has anyone here used Mathcad API and know the answer to the below query.
