It is the continue of this question SI and cm-gm: sec problem with units
At us in Russia discussions on what system of measurements the textbooks on physics for schoolboys and students should be based do not cease!
Some say that the SI is a standard (the law) and one must do everything.
Others argue that the SI created idiots, who were expelled from universities for academic failure in vain time. The system SGS created ин genius Gauss!
What do you think about it?
У нас в России не утихают споры о том, на какой системе измерений должны базироваться учебники по физике для школьников и студентов!
Одни говорят, что СИ - это стандарт (закон) и его должны все выполнять.
Другие же утверждают, что СИ создали недоумки, которых в свое время выгнали из университетов за академическую неуспеваемость. Систему же СГС создал гениальный Гаусс.
Что вы думаете по этому поводу?
I think it is very important that people al over the world use the same standards as much as possible, especially since the world is 'getting smaller' day by day. That is no less important for scientists than for trading folk. One set of unit standards makes for better understanding and less errors.
About the only thing I can say FOR the CGS system is that it uses the gram, rather than the kilogram as the base unit of mass. This means in the CGS system you can apply prefixes p (pico), m (milli), M (Mega) and P (Peta) for pg, mg, Mg and Pg respectively, directly to the base unit. In SI you can't: pkg, mkg, Mkg and Pkg are NOT allowed.
But the CGS system has a similar flaw. The CGS system uses the cm as a base unit for length, with the same problems there.
Other than that I think the SI is a superior system that, together with the definitions of the base units has evolved well over time and is still evolving for the better. This year a big change is coming. We're finally stepping away from the prototype 1 kg that is kept in Paris as the standard for the base unit for mass. See here:
https://www.bipm.org/utils/en/pdf/si-revised-brochure/Draft-SI-Brochure-2018.pdf
Proposals to clarify the meaning of most of them have good prospects. The stumbling block was a kilogram, because there is a standard, but it is subject to changes, and this causes regular disputes in the scientific environment. A number of experts propose to determine kilograms, based on the value of the Planck constant. In addition, it is proposed to give a kilogram a new name. The fact is that a kilogram is the only basic SI unit with a multiplier of one kilo. A contest for the best name for the updated basic unit of mass will be announced, and she herself, as noted above, will be tied to the Planck's constant, and not to the platinum-iridium standard of kilograms stored in the Paris Chamber of Weights and Measures.
The standard of kilogram, which became unnecessary by this moment, is planned to be handed over to the winner of this contest. The most likely thing is that the name stein with the abbreviation of st and the derived units mst, mcst, etc., will win here. Stein, it's more likely that ein Stein is a German a stone - one object with a mass . On the other hand, it is the root in the name of the brilliant physicist Einstein, who for various reasons has not found himself in the "pantheon" of the basic and production units of measurement. In the name of Einstein, only a little-valued extra-system unit for the number of photons is used, which is used in photochemistry, and even very rarely. Replacing the kilogram by the stein will correct this injustice.
I remembered this limerick:
"There was once a family called Stein,
There was Gert,
There was Ep,
There was Ein.
Gert's writings were bunk,
Ep's statues were junk,
An no one could understand Ein."
(from: "Breakfast with Lucian. A portrait of the artist." by Geordie Greig)
I think that Bern was also part of that family. A composer and conductor.
Einstein, Newton and Pascal played hide and seek. Led dropped Einstein. Pascal fled into the bushes, disguised himself, do not see the man at all, but Newton just stands - drew a 1m*1m square around and stood there.
Einstein counted to a hundred, turns, sees Newton and screams:
- Hooray! I found Newton!
Newton smiles cunningly:
- Wrong, wise man! This is Newton per square meter! YOU FOUND PASCAL !!!
Энштейн, Ньютон и Паскаль играли в прятки. Водить выпало Эйнштейну. Паскаль убежал в кусты, замаскировался, вообще не видно мужика, а вот Ньютон просто стоит. Нарисовал вокруг себя квадрат и стоит.
Эйнштейн досчитал до ста, поворачивается, видит Ньютона и кричит:
- Ура! Я нашел Ньютона!
Ньютон хитро улыбнувшись отвечает:
- Обознатушки-перепрятушки! Ошибся, умник! Это Ньютон на квадратный метр! ТЫ НАШЕЛ ПАСКАЛЯ!!!
The unit Pascal is too small and it almost always has to be used with multipliers of kilo, mega or giga. Because of this, in science and technology there are still in use alternative pressure units-atmospheric atmospheres, technical atmospheres, bars, meters of water column, millimeters of a mercury column (torr), etc. Such variety so? It often leads to errors in the calculations. It is planned to hold a kind of "denomination" of Pascal - the basic unit of pressure will be "new pascal", equiv. valent 100,000 to the old Pascal. At the same time, a certain transition period will be established, when it will be possible to use both old and new units of pressure, and then old Pascals will be withdrawn from circulation.
