Is it possible to export out a scalable vector file from Mathcad prime worksheet? If yes how can I do that?
There is no means built specifically into Prime to construct and save SVG (Scalable vector graphics) files.
SVG files are simply text files so it is possible with a bit of work to construct a matrix of SVG text and save this with Prime function WRITETEXT to an *.svg file..
Cheers
Terry
Hello @JH_9781973,
Thank you for your question.
I'd like to recommend to bring more details and context to your initial inquiry.
You could add details like:
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Vivek N
Community Moderation Team.
Cheers
Terry
Have enclosed extra function that deals with the quotation marks
Hello @JH_9781973,
It looks like you have some responses from a community champion. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
