The percentage operator in the result is getting scaled to 1% after converting it to prime. Is there any way to avoid this ?
I agree that this display is nasty as is the display if the imaginary unit showing the leading "1" in an expression like this
There is not much you can do against the converter producing this display, but there are some workarounds if you are willing to manually edit each affected expression.
Prime 9 worksheet attached.
Just delete that expression and re-evaluate A1. If you want the result in %, type 100% after the result:
That I know and understand. I want to show it in similar way it used to seen in 15
How to achieve this in Prime?
