Shading Area Between Two or More Functions
Cornel
How can make a function that shades (automatically) the area between two or more functions?
Thank you.
(To:Cornel)
There is no shading option but you can create a program which generates hatch lines. If you chose them close enough it looks like shading.
If you search the forum you'll find a couple of different ways to program it.
Attached is a simple one which should help. Also attaches a variant using the "stem" plot type (you might also try "bar" or "solidbar") but thats not suitable for all purposes.
(To:Cornel)
Cornel
(To:Werner_E)
Ok.
They will most likely reappear some things related to shading certain areas (for multidimensional calculation), but I will post at that time.
Thank you very much for your response.
