Shift+space key conflict with Windows 10 system input method editor when edit table
jlee-10-11-12
Shift+space key conflict with Windows 10 system input method editor when edit table in Chinese Simplified version Operation system.
problem:
I want to insert a column in table, when i press Shift+space key, table doesn't has any change, but Windows 10 system input method editor change from half characters to full characters.
Like the picture below :
problem solution:
install a new English language to system, when you want to add a new column to table, change the language from local language to English.
Request:
Could PTC MathCAD engineering team change the hot key "shift+space" to others or add switch options?
Considering the rate at which PTC implements features, you better get used to using the ribbon buttons for inserting rows and columns:
Thank you, that is the only solution which is faster and better than add a new language in my post.
