Hello;
I have 5 equations 5 unknowns in the solve block which all of them are functions of a range variable. Solve block always gives error, what is wrong?
Please see the attached mathcad file below. Thanks for help
I didn't understand what you have done but tried as you show but it doesn't give any result???
Send please the sheet!
It is very difficult to edit not own sheet.
I have showed you not a solution but a direction to solution.
You must solve a normal system but delete one variable in the guess values area and create a function with this argument.
