Solve Block for Range Variables
atbarajas
Hi everyone,
I'm currently working on a Mathcad document that requires iterations at some point to solve for a value, so I decided to try and use solve blocks. the only problem with this, is that I use several range variables. I read online that you can trick a solve block to work with range variables if you define your range variables as functions, but one of my parameters relies on the sum of a range variable. Does anyone know if it's possible to get this to work?
Thanks for your help,
Talina
Like attached perhaps? (Best not to use range variables as ordinary variables)
Alan
Alan
Thank you so much! It never even occured to me to vectorize my values.
Thanks again.
Talina
