Solve, N, fully ?
lvl107
20-Turquoise
Solve, N, fully ?
Hi, Everyone.
From the following:
How to solve, N, fully (the above) ?
Thanks in advance for your time and help.
Best Regards.
Loi.
LucMeekes
(To:lvl107)
I'd say: Fun(N)=1, solve, N, fully
should give: N is odd.
8 REPLIES 8
(To:lvl107)
Isn't the solution N = infinite ?
LucMeekes
(To:lvl107)
(To:LucMeekes)
I agree. My assumption N=infinity was grossly incomplete 😉
Is Maple in MC11 able to prove it? muPad in MC15 isn't:
Problem is the first summand in Fun(N) (Mathcad changes the order in the result) as already seen here: https://community.ptc.com/t5/Mathcad/Sum-of-reciprocals/m-p/827578/highlight/true#M202986
LucMeekes
(To:Werner_E)
Note that you should not assume n>0, since n=0 gives 2*n+1=1, the first odd number.
Can maple prove it?
Let's try:
That's equivalent to MuPad's result. Setting n to a n integer:
The command simplify:
Doesn't simplify, but simplify, max:
creates a different result, I've never seen simplify, max create a different result from simply simplify in Mathcad 11.
But then again, simplify, simpler  creates that very same result:
(To:LucMeekes)
In MC14/15 "simplify,max" often makes a difference, but apart from taking much more time it also sometimes returns a result which is even worse compared to the one we get with "simplify" alone.
BTW, "simplify,simpler" throws the error "Modifier is unknown or not allowed here" in MC15.
LucMeekes
(To:Werner_E)
Mathcad 11 doesn't know that error message. It allows anything as a modifier for simplify. But it's striking to see that an absent modifier gives a (slightly but) different result from a non-empty modifier.
lvl107
20-Turquoise
(To:LucMeekes)
Many thanks, Luc and Werner.
Luc, with your suggestion above, And I agree with you, too:
Best Regards.
Loi.
(To:lvl107)
Here is a list for the first few N showing N, the reduced first an second summand and the complete sum.
Some sort of pattern can be seen, but the proof is .... ??
