Solve System of Differential Equations
Suki
Hi I am trying to solve system of 2 ODE as shown below. I am unable to find out the issue.
The error happens when I m trying to relate the first ode to the second one. I am getting error as "Unknown error: ode% _function% _illegal % _context. Please help!
12 REPLIES 12
LucMeekes
(To:Suki)
Please attach your Prime worksheet.
Suki
(To:LucMeekes)
Hi Luc,
The calculation has been done at the bottom of the mathcad sheet. Please see attached.
Sukrit
LucMeekes
(To:Suki)
Have a look here https://community.ptc.com/t5/Mathcad/Multiple-ODE-s-in-MathCad/m-p/785905#M200434
Similar problem, solved.
Suki
(To:LucMeekes)
So its not possible in Mathcad Prime in a solve block?
Symbolic Math is not incorporated well in the Mathcad software like Mathematica.
LucMeekes
(To:Suki)
It IS possible using a solve block, but it takes a little effort. Have a close look on what @Werner_E accomplished in that thread.
Alternatively you should be able to solve it symbolically in Prime. For that you'd have to make use of my latest addition to https://community.ptc.com/t5/Mathcad/Toolbox-Solving-Ordinary-Differential-Equations-symbolically/m-p/689336#M192090 .
Suki
(To:LucMeekes)
Feature does not work on Mathcad Prime. 😞 MATHCAD so full of bugs.
LucMeekes
(To:Suki)
With your set of ODE's this is the result:
but if your ode's are
and
you may get:
See attachment for further details.
(For further information on the solving of ODE's refer to https://community.ptc.com/t5/Mathcad/Toolbox-Solving-Ordinary-Differential-Equations-symbolically/m-p/689336#M192090 and have a look at the Prime file in there.)
Hmm!
Express, using integration and boundary conditions to solve for constants of integration:
Hi Fred,
I guess yours is the correct result.
After checking a few items in my sheet, I find that the solution of w00 through w07 is incorrect.
If I have time later, I'll check my method with Mathcad 11.
Found the culprit. Prime has this nice '-operator (quote, gives the derivative), but it is apparently only intended for single parameter functions, such as f(x), but not for f(x,y,z).
So I ended up defining the derivatives explicitly and then solving for the initial conditions. That results in the correct answers.
Suki
(To:LucMeekes)
Thanks Luc, it looks like a solution without using solve block feature.
I might write 8 equations by integrating each of the Differential equation 4 times and then substitute the boundary condition and solve the problem by finding unknowns. The program does not automatically catch boundary conditions establishing a relationship of one differential equation to another.
Fred_Kohlhepp
23-Emerald I
(To:Suki)
I can't use solve blocks (I only have Express), but by integrating and applying boundary conditions to evaluate integration constants we can still address this problem.  I doubt that you intended to set such a simple problem.  Attached is Prime 4 discussion.
