Solve block as a function
MikeArmstrong
In the attached sheet I have used the symbolic solve operator to find the required variable. (m.gn)
I have heard people talking on this forum about defining a function that references your solve block, then use that function within your program.
Can anybody either confirm if this is possible or an alternative to the solve command.
Regards
Mike
10 REPLIES 10
On 8/25/2009 5:25:18 AM, Armo wrote:
== In the attached sheet I have used the symbolic solve operator to find the required variable. (m.gn)
== I have heard people talking on this forum about defining a function that references your solve block, then use that function within your program.
== Can anybody either confirm if this is possible or an alternative to the solve command.
See attached. (M11 format)
Stuart
MikeArmstrong
(To:StuartBruff)
Cheers Stuart, that works great can that be put into a program?
Regards
Mike
On 8/25/2009 5:51:51 AM, Armo wrote:
== Cheers Stuart, that works great can that be put into a program?
Umm, depends exactly what you want to do. If you want to use symbolics then the entire program gets solved symbolically ...
You can certainly call f(...) from within a program.
Stuart
MikeArmstrong
(To:StuartBruff)
I have attached a sheet of exactly what I am trying to do.
You can see that I have written the calculation in a program and used the answer from the solve function for m.gn, but, if possible I would like to incorporate the solve function into the program.
Regards
Mike
Is this what you want to do?
Richard
MikeArmstrong
(To:RichardJ)
Yes cheers Richard.
Spot on.
Regards
Mike
On 8/25/2009 9:44:25 AM, Armo wrote:
>Yes cheers Richard.
>Spot on.
>Regards
>Mike
________________________
You three, are bombarding from too close range,
I have to go for the day, get inspired by the green.
No problem to include ranged 'r' !!! but a more involved way
jmG
Get inspired for your ranged 'T', 'r', 'Alpha'.
jmG
MikeArmstrong
(To:ptc-1368288)
jmG
Am i missing something.......
Can't see the correlation to mine.
Regards
Mike
>do.
>Regards
>Mike
______________________________
This is not a case of passing a solve block in a programme. Below Marlett is a case of passing a solver in a programme. Colebrook that I passed is a case of passing a solver in a programme and iterating for a family of solutions. You better go yellow "the Engineer way". You can't resist plugging units ... is it ? !!! Always check any function by plotting.
jmG
