In this exercise section you will practice solving equations with the methods you learned in the Tutorial to solve complex problems involving more than one equation. As you go through each exercise, we will also point out how the symbolic equal sign = allows you the flexibility to work up to the final answer, rather than try to “define the relevant equation(s)” all in one step.
