I am not getting why this is evaluating in such a way in Mathcad 15
Hi
You can use a setting in the worksheet options:
Simply uncheck the use exact comparisons option.
If you uncheck the exact equality option you get the behavior desired.
Cheers
Terry
Hi
Internal precision at 17 decimal places A and 1.5B are not the same.
Thank you for explanation I was just wondering if there is any option with mathcad 15 to change this behavior with variable?
Hi
Cheers
Terry
