On 5/9/2010 2:38:14 PM, dvmoldovan wrote:
>First, thank you all for your
>time and energy put to my
>rescue. Although your answers
>may sometimes have been not
>what I hoped for (initially),
>you all pointed out several
>flaws in my sheet (and data).
>With you permission I'll start
>over (still based on what has
>been posted here so far).
>Second, let's assume the
>following :
>1. from experiments one has
>gathered data for strains
>(column 1 - microns) and the
>response in stress from the
>material (column 0 - newtons)
>2. there is one function to
>link them together (as
>proposed by Wang)
>The question is, how can I
>achieve the best fit between
>experiments and Wang?
>I attached my latest work, but
>it doesn't feel right due to
>that inflection point...
>Please disregard erratic data,
>discontinuities and others.
>I'm trying to understand the
>principle and the formulas it
>should use before collecting
>any more data...
>Kind regards, D.
____________________________
"1. from experiments one has gathered data for strains (column 1 - microns) and the response in stress from the material (column 0 - newtons)"
==> Total non sense: strain is a calculated ratio, dimensionless.
I don't understand negative pressure unless the sensors have inverse polarity or the calibration is zeroed at 2500. But you can see that the project is reversed. So, we are back to square 0, i.e: read the pressure from a dial meter and the deformation from a dial meter too, with much less measurements.
![](/upload/Unk475.gif)
During testing of a material sample, the stress�strain curve is a graphical representation of the relationship between stress, derived from measuring the load applied on the sample, and strain, derived from measuring the deformation of the sample, i.e. elongation, compression, or distortion.
In continuum mechanics, stress is a measure of the average force per unit area of a surface within a deformable body on which internal forces act. It is a measure of the intensity of the internal forces acting between particles of a deformable body across imaginary internal surfaces [2]. These internal forces are produced between the particles in the body as a reaction to external forces applied on the body. External forces are either surface forces or body forces. Because the loaded deformable body is assumed as a continuum, these internal forces are distributed continuously within the volume of the material body, i.e., the stress distribution in the body is expressed as a piecewise continuous function of space coordinates and time.
The SI unit for stress is the pascal (symbol Pa), which is equivalent to one newton (force) per square meter (unit area). The unit for stress is the same as that of pressure, which is also a measure of force per unit area.
Strain is the geometrical measure of deformation representing the relative displacement between particles in the material body. It measures how much a given displacement differs locally from a rigid-body displacement.[1] Strain defines the amount of stretch or compression along a material line elements or fibers, the normal strain, and the amount of distortion associated with the sliding of plane layers over each other, the shear strain, within a deforming body.[2] Strain is a dimensionless quantity, which can be expressed as a decimal fraction, a percentage or in parts-per notation. This could be applied by elongation, shortening, or volume changes, or angular distortion.
The Cauchy strain or engineering strain is expressed as the ratio of total deformation to the initial dimension of the material body in which the forces are being applied. The engineering normal strain or engineering extensional strain e of a material line element or fiber axially loaded is expressed as the change in length �L per unit of the original length L of the line element or fibers. The normal strain is positive if the material fibers are stretched or negative if they are compressed. Thus, we have
where is the engineering normal strain, L is the original length of the fiber and is the final length of the fiber.
The engineering shear strain is defined as the change in the angle between two material line elements initially perpendicular to each other in the undeformed or initial configuration
jmG
