Subcripts in Mathcad prime
OM_10154742
7-Bedrock
Is it possible to use colan (:) symbol in literal subscripts for defining variable in Mathcad Prime directly ?
5 REPLIES 5
Not directly, as far as I'm aware.  I've tried a few workarounds, such as using a Unicode subscript colon, but there isn't a subscript colon.   However, one possible workaround uses a variant of the colon character.
The text string is: (@ID g (@SUB l꞉k))
Modify it as needed.
Stuart
(To:StuartBruff)
You can use the usual colon character if you put the subscript text into double quotes
A somewhat startling observation: If only part of the subscript text is set in double quotes, the order is changed
StuartBruff
23-Emerald V
(To:Werner_E)
Interesting. It further seems to strip spaces outside of quotes and possibly use the space as some form of grouping break.
Stuart
This is clever.  I knew about inserting special characters and I know about the underlying equation notation, but I never thought of putting the two together.  Here are some use cases that I've been wanting to apply for some time now.  I'm sure there are infinitely more.
StuartBruff
23-Emerald V
(To:JeffH1)
Neat.   It's also possible to automate the production of suitable strings by concatenating appropriate substrings.
Alas and alack, my long-standing request to directly create variable/function names has not been implemented, so the last part, the tiresome manual copy/paste,  is still an unwanted drudge ... although, I suppose one could Autokey, or similar, the process.
The functions unichar and unistring are simple functions that convert a decimal/hex number into a Unicode character or string, respectively.  I'd post the worksheet, but it's rather a dreadful mess and I'd be ashamed to visit it upon the web.
Stuart
