Surface plot
SFares
Surface plot
i am trying to plot this surface, but it is not showing. not sure what i am doing wrong. Thank you!
See the attached for one possibility. You can play with the appearance to your heart's content.
Alan
8 REPLIES 8
Alan
SFares
(To:SFares)
Thank you Alan!
what was wrong with the way i was doing it? i thought mathcad will draw the surface without "Ceate Mesh" command.
tdevaraj
(To:SFares)
In Mathcad 15 when you are plotting a function, you need write the function name f in the placeholder. and not f(x,y) as you had done.
In Prime you can do write it both ways, function name only or function name with arguments.
SFares
(To:tdevaraj)
Thank you Thomas!
SFares
(To:tdevaraj)
Hello Thomas,
The shape that i have pasted in my sheet for the end result does not match what you are showing. what needs to be done? Thank you!
tdevaraj
(To:SFares)
oh, I may have rotated the plot slightly and zoomed in on it ... nothing else.
SFares
(To:tdevaraj)
Thomas,
The plot you have does not match what Alan did. Is there away by using your method to plot the function to look like Alan's?
Compare the following:
I prefer the CreateMesh version!
Alan.
