Symbolic 2nd order ODEs using Prime 3.1?
I am not sure if my syntax is correct but for some reason Mathcad Prime 3.1 will not solve the following simple 2nd order ODE symbolically. The ODE has this form v''(x) + v(x) = 0 which i believe is the same form solved by Euler. This equation is used to calculate the column buckling equation used by structural engineers. it would be disappointing to learn that math done more than 250 years ago still cannot be computed by the latest version of Mathcad. I would find it hard to believe that MuPad symbolic engine dosen't have such functionality? Is there some hidden software switch in Mathcad to enable full symbolic capability? Or maybe someone could show me a workaround. I am just interested to see if Mathcad gets the same result as in the text book. Mathematica certainly gives an unreconisable form of answer, to me at least when done by hand.
Thank you in advance Mark
