Greetings friends of the forum.
I have the following query: I need to symbolically simplify the following function.
Using the following operators that I know of, I do not get a simplified answer:
Writing the function exponentially, I also do not get a correct answer:
Working in parts if I get the answer:
There is some symbolic operator or modifier that allows me to calculate without doing it in parts????
I appreciate any suggestions or help.
First realize that it is hard to control the output of the symbolic processor of Mathcad (and Prime) exactly to one's desire.
Here's my result in Mathcad 11 (with Maple)....Not so easy, maybe you have more luck in Prime when you assume that x > 0:
Note that the last result is not complete. I chopped off several pages of the width!
Thanks for your solution Luc. Working with Mathcad Prime I get what I was looking for:
