Taking forward the result values of Find function
ptc-4766784
Hello Friends,
I have solved a set of equations to find two unknown values by using Find function. But I couldn't able to use the values which I got as result for further calculations. I think its because I have defined the unknown variavles with assumed values.
Can anyone help me to resolve this?
Venu
You need to assign the results to a variable, see the attached.
Mike
Mike
Thank you very much Mike.
No problem at all. You are welcome.
Mike
