As a source of initial data, I use Excel files. When trying to find the values in the table by using "hlookup" function is working for a file "Data 1" and does not work in the case of the data from the file "Data 2". Why?
With "Data 1":
With "Data 2":
With "Data 1":
With "Data 2":
Just to add to what Mike's written (I haven't looked at his worksheets yet), for Data 1, hlookup tries to find 1 in the first row of Результаты_тензометрии, which it does in column 1. The match function returns 126, so hlookup then returns the value in row 126 of column 1.
However, in Data 2, 1 doesn't occur in row 1 (only 13 and 4.39 are in row 1), so it flags an error up.
Stuart
Remember hlookup looks in the first row of a matrix.
From the help:
hlookup(z, A, r) Looks in the first row of a matrix, A, for a given value, z, and returns the value(s) in the same column(s) in the row specified, r. When the value(s) are returned, they appear in a vector, starting from the left.
Mike
No, I do not need other approaches to solving this problem, as it was seen from my first screenshot I found a workaround. I only had to deal with the "hlookup" function. Thanks.
With "Data 1":
With "Data 2":
Stuart
Yes, I missed in the initial data "1". Thank you.
пожалуйста, нет проблем, владимир
Stuart
