The solution of the integral below should have an imaginery part but only shows the real part
rdelascasas
6-Contributor
I need to calculate the semi-infinite integral that appears in the attached pdf file and the solution should have imaginary part. But, for some reason that I do not know, it is just given me the real part.
j inside the integral is the imaginery term.
Thank you in advance,
Rogelio
(To:rdelascasas)
Second approach using a different program (Derive 6)
Using this information, Mathcad is able to yield the correct result:
Again with the help of Derive we can rewrite your function J so that even Mathcad yields the correct results:
11 REPLIES 11
Attaching your worksheet using the advanced editor (see the upper right-hand area of the normal editor) will help people see what you are doing. I strongly suggest you do this.
(To:rdelascasas)
You are right, one would expect an imaginary part.
Numerical deficiency or bug? Guess the first.
Did you try symbolic eval? I had to stop - it took too long.
(To:rdelascasas)
rdelascasas
6-Contributor
(To:Werner_E)
Mr. Werner,
I really like what you have done here.
But I do not "see" how you arrive to this form for the square root complex component.
Can you give me a reference where i can read about this?
I have several problems to solve that will all include this kind of solutions. If I can learn how to arrive to these complex component, in the way that you did, that will be terrific!!
Thank you very much for all your help.
Rogelio
(To:rdelascasas)
Rogelio de las Casas wrote:
Mr. Werner,
Rogelio
Sorry, as already written I have not done the transformation myself by hand but had used another math program to do the job and simply retyped it. Later I tried if Mathcads symbolics would do the trick (using the modifier rectangle) but I had no succes - maybe I tried not hard enough, as Mathcads symbilics can be quite tricky.
See attached.
I have just gave it a try and found a way to do the transformation manually with the term, that can throw complex results, using Mathcad only to solve a system of equations. Don't worry about the red errors, they apply only to numerics, we use symbolics here. It would be more correct to write L(my):=...
and a(my):=L(my)[0,0 etc.
rdelascasas
6-Contributor
(To:Werner_E)
Thank you, that was good and looks simpler after you explained it.
I really appreciate all your help on this.
Rogelio
(To:rdelascasas)
Glad I could help.
Its a shame that Mathcad doesn't do it on its own.
After thinking over it I have to change my mind - it seems to be a bug
But at least we have a workaround, thanks Derive.
BTW, the same error (the integral yielding the realparts only) is seen in Prime2, too.
Werner,
I tried the solution of mathcad for the square function from your previous message and it did not work.
I have attached the file that you sent me first with some comments.
The good thing is that your first solution from Derive, did work very well and I could reproduce the examples from the paper that I was studying.
Thanks again
Rogelio
(To:rdelascasas)
I am not sure if we see the same, if its a version conflict (I am using Mathcad 15 M020) or maybe only a misunderstanding.
I include a worksheet with a manual proof that the expressions by derive and MC are equivalent.
Also a pdf of the file so you see how it looks for me
(To:rdelascasas)
I added at the end a definition of J based on the results from Mathcad and it seems to wirk well.
I furthermore added the parameters so that the numerics are happy, too, now.
rdelascasas
6-Contributor
(To:Werner_E)
Yes, you are right.
when I did the simplification, i did not notice that whatever I have at the end equals 1 !!
