There is no keyword named [_], Solving unknown variable
MelB
3-Newcomer
See snip below & attached. I'm trying to solve for z_pna, such that the sum of the tension forces equals the sum of the compression forces.
LucMeekes
(To:MelB)
The variable you want to solve for needs to be part of the equation. That is not the case above. You should have z_pna be a parameter to both  SigmaT and SigmaC. This in turn means that also Tsr and Csrw must be functions, with z_pna as a parameter.
Considering that all other items are numerically defined, there's no need to try to solve this symbolically (which you do when you use that arrow). Better try a numerical solver, such as the root() function.
And when you really do want to use the symbolic solver:
1. You need to use the 'solve' keyword.
2. You should consider that the symbolic processor does not know about units by default, and while there is a setting to let it take account of them, sometimes it simply doesn't work.
LucMeekes
(To:MelB)
(To:LucMeekes)
How true! In case of this example it works OK,  though. You might have to recalculate the sheet once or twice.
But I fully agree that if just a numeric result is looked for, a numeric method like a solve block or the root function should be used, rather than the unit-unaware symbolic "solve".
