Thermodynamic Properties of Gas Hydrates
ValeryOchkov
I have read that there is a big problem with Gas Hydrates in Gulf of Mexico with the BP Leaking oil stop!
See:
Thermodynamic and Crystallographic Properties of Gas Hydrates with mathcad help and for Mathcad: http://twt.mpei.ac.ru/TTHB/2/HG/index.html
Val
http://twt.mpei.ac.ru/ochkov/v_ochkov.htm
>Leaking oil
>stop!
See:
Thermodynamic and
>and for Mathcad:
>G/index.html
Val
http://twt.mp
_______________________________
Not clear from the media what the technical problem was. It looked the Venturi effect created by the chimney was enough to cool down to the crystal point of the H2S. Same problem happen in the extraction of heavy water [Girder process]. It causes the plant to shut down and the rest for about 6 months, wrapping the towers in plastic and heat the bloody thing.
jmG
