Please upload your sheet so we can help'
Cheers
Terry
@RL_13320206 wrote:
This variable is not defined. Check that the label is defined correctly.
The variable is defined, redefined, calculated, recalculated, but it still shows me a red error when I include the variable in an equation.
The variable you use in your equation may be labelled differently from the variable you had defined. Primes autolabelling tries to find the correct label and apply it but also often fails doing so.
There are also other causes for that error message possible.
We hardly can say more unless you attach your worksheet for inspection.
Or is it the same question which was already answered here: Solved: Re: The variable is undefined. Check that the label
I told you that's it a bug and that you can avoid the error by not using inline evaluation.
