Trace funcition and window not working
pblbailey
I am using windows Vista first of all...I don't know if that has anything to do with this problem or not. But, there are several things that don't seem to be working right in my version of MathCad 14. One thing right away was when I placed and Excel 2007 component with column labels in my worksheet and redefined the properties of the labels to maker sure they were defined in my work sheet ...they were never usable. Then the execution of any loop programs did seem to either work at all or would have no output. Then I tried the debugger toggle and trace window. The trace window opens but nothing is ever in that window. I even opened a blank worksheet and copied the the trace example in the help quick sheet section. I ran the = (execution) command with debugger ...nothing. So something has got to be wrong with math cad program..right?
HEELP!....
20 REPLIES 20
About trace function:
On my notebook (Win XP, Mathcad, version 14.0.0.163) - all is OK:
but on my PC ((Win XP, Mathcad, version 14.? I will see tomorrow) - no OK: I have an empty trace window too.
Val
PS
See users tools for tracing+vizualization
http://twtmas.mpei.ac.ru/mas/Worksheets/Min-2-step-test-1.mcd
(the task of the next message on this forum)
http://twt.mpei.ac.ru/ochkov/v_ochkov.htm
Tracewindow OK here on my notebook with Mathcad 14.0 M030 (14.0.3.332).
Maybe an installation problem?
I have witnessed quite often, that the installation routine is not really a clean one. Installing on a proofed clean system ever so often results in a lot of registry errors found by some of the common (and sometimes dangerous) registry cleaners.
RMix
RichardJ
(To:pblbailey)
Which version of 14 are you running?
Richard
The trace function does not work on the task in attach. But with the root function - no problem!
In Mathcad 13 was no problem with thw Minimize function!
See:
Val
Not only that the trace window stays empty, if I recalculate the minimize-expression it gets red moaning about "This varible is undefined". (MC14M030)
R
RMix
>about "This variable is undefined".
>(MC14M030)
>R
>RMix
>___________________________
Maybe it would like to say "guess wisely from a contour plot". With that kind of guess, Valery is even lucky to get some garbage solution. Don't forget that the entire numerical world seats between 0 ... 1. With that kind of guess, the solver flies in many "non machine numbers", if it does not evaluate, then no trace. Try again, try wisely.
jmG
>... Try again, try wisely.< ... this one.
jmG
>(MC14M030)
In your and Valery's case there is no bug. The help says the control string is optional only for the one argument case. With two variables and no control string, you get the undefined variable message. Valery's original example is giving apparently wrong answers because he has assigned both x and y to position 0 in the control string.
Without a worksheet it's impossible to know if pblbailey is seeing a real problem. Given the description it sounds likely, but they never told us which version of Mathcad 14 they are using, so maybe all that is required is the service release.
Richard
>stays
>the
>moaning
>undefined".
>(MC14M030)
In your and
>control string.
Without a worksheet
>release.
Thanks, now I see me error!
But
0.992383364744604, 0.992383364744604
5.9923833647446, 5.9923833647446
etc
is better than
x=0.992383364744604,y=0.992383364744604
x=5.9923833647446,y=5.9923833647446
etc
for the ploting on the graph
Val
On 1/26/2010 2:52:13 AM, VFO wrote:
>But
>etc
>is better than
>etc
That must be a matter of preference, because I prefer to see the variable names. If all you want is 0.992383364744604, 0.992383364744604 though, change the control string to "{0},{1}".
Richard
>>But
>>etc
>>is better than
>>etc
>"{0},{1}".
>Richard
Thanks - ��� ���� - ��� �����! How it is in English?
Val
On 1/26/2010 8:18:07 AM, VFO wrote:
== ��� ���� - ��� �����! How it is in English?
You Live and Learn?
Stuart
>English?
>You Live and Learn?
>Stuart
Not
You Live and Learn - I say only to You!
��� ���� - ��� ����� - I say myself or too all general!
Val
>>English?
>>You Live and Learn?
>>Stuart
>Not
>too all general!
>Val
There are a thing that nor Val or I understand in the english syntax of the translations: it is the "you".
For example: "Every day you learn something new" is the google translation for the common phrase "todos los d�as se aprende algo nuevo", which in spanish it's impersonate, refereng to nobody in particular.
I think that what Valery says is what are doing the "you" into the translations?
Regards. Alvaro.
RichardJ
(To:AlvaroDíaz)
>translations?
It is a very common misuse of English. So common that many people don't even know that it's technically wrong, and so common that everyone accepts it even though it is wrong. The phrases really should be "One lives and learns", or "Every day one learns something new".
Richard
On 1/26/2010 11:53:45 AM, rijackson wrote:
>It is a very common misuse of English. ...
Thanks for the explanation.
Regards. Alvaro.
>in English?
Google translates it as "You live and learn", which is also a common English phrase.
Richard
>>in English?
>phrase.
>Richard
Thanks!
But Mathcad developers must learn too!
Why trace(x) is possible but trace(x,y) not?!
And second.
It will be good direct (how?) use trace data on plots for example:
MCS:
Val
>not?!
I don't know why the control string is required for more than one argument. An arbitrary decision by some developer.
>And second.
I agree.
Richard
==> YES ! no comment [jmG]
==> As explained in my previous post: complex values are likely to be there, therefore somebody forgot to specify for complex as well ! [jmG]
>And second.
==> In reality not very wise to see some king of zigzag , looking more like a bird drop ... and complex again !
Guess wisely and it goes [jmG]
>MCS:
>Val
