Transcendental Equations
DavidWilloughby
Can anyone assit with the best way to solve a trancendental equation in Mathcad. The last equation in the attachment is an example of the equation I am try to solve.
On 1/26/2010 12:54:01 PM, dwilloughby wrote:
>Can anyone assist with the best
>way to solve a transcendental
>am try to solve.
_____________________________
http://en.wikipedia.org/wiki/Transcendental_function
If you have no answer: "Save as " version 11
jmG
In general transcendental equations have no closed form solutions. You use find to get a numeric solution.
Note that your definition of j does not make j an imaginary number. Rather it makes j an angle. For the unit imaginary, use the form 1j.
__________________
� � � � Tom Gutman
>am try to solve.
_______________________________
Mathcad 11 does not read higher versions.
"Transcendental functions", i.e: algebraic equation are generally solved in closed form via special functions. Here solving with Lambert (W). 15 examples attached + an example of symbolic indexer.
jmG
