Trial and error method in mathcad
The following is the equation in which , the value "f" should be zero, but the integration limit has to change with the y1 value,
i.e if y1<z1 the equation will be same as shown,
if z1<y1<z2 , then y1 must be in the P2(z) integration limit ,
also if z2<y1,then y1 must be in the P3(z) integration limit
Keeping the fact that using trial and error "f "must be zero and the equation must change the integration limit as per the "y1" value.
| y1 = | 3.26 | Solve by trial & error until f = 0 | Q = | 1192 KN | ||||||
| z1 | z2 | y1 | ||||||||
| f = | Q - ∫(P1(z,ϕ1)dz - ∫(P2(z,ϕ2)dz - ∫(P3(z,ϕ3)dz | |||||||||
| 0 | z1 | z2 | ||||||||
| f = | 0.00 | |||||||||
