Units are not compatible
MK_9124307
2-Explorer
Hi!
I have a very bizarre error that I just can't solve.
See the following:
This gives me the "units are not compatible error" if I use t_uZkplus.max.
If I put the solution for t_uZkplus.max manually in the lower line it works just fine:
I really don't understand what is going on here. Does anybody have an idea?
(To:MK_9124307)
Looks indeed strange, but as Fed already wrote, without seeing the sheet itself we can only stab in the dark.
So if possible you should attach the worksheet or a simplified, down-stripped version of it showing the same behaviour.
You may use the error tracing - maybe knowing the line in the function u.Zkplus_Int( ) which throws the error can help in finding out what happens.
A significant difference between real Mathcad, where your original file stems from, and Prime is, that Prime is not using SUC (static unit checking. This means the something like 0 + 12 V = 12 V, which works OK in Mathcad, may (must not!) fail in Prime because Prime often needs a unit even if the value is zero.
The converter is not fixing situations like that and it can be quite hard to find these stumbling blocks in a converted sheet.
It doesn't look to me that this could be the cause in your case, but can't say for sure without seeing the sheet.
5 REPLIES 5
Without the sheet to investigate, we can only guess.
I suspect you have run afoul of the dreaded label issue.  Prime may not always recognize what each .variable unit is.  Check
Unfortunately it is already labeled as a variable.
What is even more weird is the fact that it depends on the value of t_uzkplus.max.
As in the opening post it doesn't work if the result is 6.667 ms (well it works with 6.667 ms if I manually copy the result into the function):
But it does with a different value:
EDIT: I don't know if it's important but that sheet was converted from an older version of Mathcad where everything worked fine...
(To:MK_9124307)
Thanks for that tip! I didn't know about that feature. I was able to find the source of the problem.
Before I had 0 instead of 0 s and that gave me the unit error. Now everything works fine.
Thanks again!
That was indeed the problem.
