Hi all,
I have a solve block function inside a program. The program iterates through an array, finding a solution for each element in the array. The problem is that the initial guess value does not work for all elements in the array. I would like to be able to use the previously calculated solution as the new guess value for the solve block. Is this possible?
I can't post the whole sheet, but I've attached an extract which hopefully shows what I'm trying to do.
So why not make the guess value an additional argument of your solve block function?
Thanks gents! A rather simple soltution...
