Upgrade MC15 from M005 to M010?
GerritBarrere
I suffered a grievous computer crash last week and had to reinstall everything, including MC15 and Prime 2.0. My distribution installation of MC15 was version M005, though, and I need M010 to be able to convert older files to Prime. I know I did this once before, but I can't find the upgrade anywhere. Can anyone give me a pointer?
Gerrit
12 REPLIES 12
Thank you, Werner, but these didn't do it. I just found from another post that M010 should be available from https://www.ptc.com/appserver/cs/software_update/swupdate.jsp , but I can't access that because my license has expired.
I was eligible for M010 while my license was active, so I should be able to get it again. Does anyone know how?
Gerrit
Not sure what the problem is. The license normally shouldn't expire I guess (it does with special agreements like volume licenses e.g. education) and looking at you profile I read "Maintenance: PtcCsMaintVerified", which would normally mean that you do not only have a valid license but also have an active maintainance agreement. So you should be able to enter the download section, I guess.
But even if not you shpould be able to download the evaluation/edu copy of Mathcad15, which, as I understand, is not different from any other version (despite of the license file of course).
Try this link: Mathcad 15.
Thanks! I downloaded and installed the latest M15, and it recognized my license file. It removed my old M005 in the process of installation. Now when I start M15 I verify that M020 appears on the About screen.
But the converter doesn't work. Here's the error I get:
"The conversion cannot be started. The issue may be caused by a previous version of Mathcad on your system. Close previous version to prevent data loss, run mcregister.exe in D:\Program Files ... \Mathcad 15, and then restart the converter"
I have shut all Mathcad programs down, run mcregister.exe, and rebooted several times in various sequences and still get this error. I think I'm close, but what's wrong now?
Gerrit
Maybe reinstall Mathcad Prime 2.0 will help. What service release of Prime 2.0 do you use (F000 or M010)?
F000. I will wait to see if there is a more rational solution before I reinstall Prime...
I would install the latest Prime2 (M010) or (if you are still under maintainance) wait a few days for Prime3 which is promised to make conversion easier.
OK, I've now reinstalled both MC 15 and Prime, re-run mcregister multiple times, rebooted multiple times, and I'm still getting the same error from the converter: "The conversion cannot be started. The issue may be caused by a previous version of Mathcad on your system. Close previous version to prevent data loss, run mcregister.exe in D:\Program Files ... \Mathcad 15, and then restart the converter"
I've got legitimate versions of MC15 and Prime, but not maintenance. I do not want to buy Prime 3 and hope that will fix this problem. I should have the capability to run the converter -- I've paid for that but it's not working.
Can someone please help me get to the bottom of this?
Gerrit
The current versions of both (MC15 M020 and Prime2 M010)?
VladimirN
(To:Werner_E)
It seems that is Prime2 F000.
