We are currently using the network license model of MathCAD and wondering if there was a way a standard user could review who has the license checked out?
LucMeekes wrote:
Wouldn't (shouldn't) FlexLM provide that functionality?
Probably not for the "standard user", I guess.
Set a batch job on the license server to run every 5 minutes or so with Admin rights and write out the license status to a readily accessible area.
I used to do something like that (when PTC had rolled their own license server) to watch license usage during the day. The first users were starting at 5am; license use peaked at 11 am and never recovered after lunch.
if FLEXnet 10.8 is installed on your license server then you can use following steps:
If you are using FLEXnet 11 (lmadmin_ptc version) then I hope you can use similar steps. I do not have these version installed, therefore I am not sure.
MH
I just checked that in case of FLEXnet 11 (lmadmin_ptc version), the above mentioned procedure works, too.
MH
I just got off the phone with tech support, for me I can see the licenses thru the web browser on the client machine:
<license server>:8090/dashboard
License info is under concurrent/hosts
Note that the license server needs port 8090 opened on the firewall to access.
