I am running Mathcad 15.0 Student version.
When I try to create a pdf by going to Print/adobe printer, the pdf is created but some of my text gets cut off, even in print preview.
Any clues? I've tried this with someone that is running the full version of Mathcad 15.0 and they have the same issue.
Thanks.
See http://communities.ptc.com/message/151389#151389
There is no difference between the versions, other than the licensing.
Have you changed the margins in Page Setup?
Post a worksheet and I'll see if I have the same issue's when opening in M14.
Mike
It has nothing to do with the MC version and is not specifically connected with pdf.
It depends on what printer you use. The cutting off may happen when printing on real printers, too.
Look at the discussion at
http://communities.ptc.com/message/151613#151613
Workaround is manually making the text-boxes a little bit narrower or using another pdf-maker.
Regards
