I have attach mathcad file here which I used while loop to test the data rows of an excel file according to an equation. I don't have any idea how that variable (in this cas Fe and Fcr) will have a new value when a new loop is executed (that is when rx1s and ry1s changes). Pls see the attach file. Your help is greatly appreciated.
Try not to cross post. The answer is in the other thread. i.e. the one entitled Re: How to read value of a matrix into a loop
Alan
Even better than trying would be to succeed at not doing it
sorry for the cross post....I can't open the file you edited. But, thank you so much for your help, I'll try to figure it out based on what you said
