Why an error in Mathcad 15
ValeryOchkov
Why an error in Mathcad 15?
One simple ODE! I have converted in Prime 4 - no problems! See please pictures and sheets
You have used a wrong syntax!
The syntax for OdeSolve is different in Prime and real Mathcad.
Correct is: alpha := Odesolve (t, t.end)
Replace alpha by t and I guess it will work OK.
EDIT: Just see your follow up. In MC11 you can see the correct syntax!
No problem in Mathcad 11 too
Thanks, Werner!
Ich hab fergessen!
Prime can work here with units but does not have an animations!
Нет в жизеи счастья!
