I had to revert back to using freeware after hitting this snag with Prime 4.0... I don't understand what the difficulty is at step 5. Troubleshooting further down the page was successful after using new variables, so it seems to be a problem with my variables...
I even tried clearing the variables like my reference "Essential PTC Mathcad Prime 3.0" textbook suggests. Any help would be greatly appreciated in getting me back going...
The problem is caused by Prime's infamous "auto labelling". Especially in combination with symbolic calculations this "feature" is usually more pain than help.
The I0 on the left hand side is labelled as "variable" but the I0 after "solve," is labelled "-", meaning "automatic". For the symbolics you are demanding to solve for a variable which does not even occur in the system of equations.
You have to change the label of one of the I0 to match the other, e.g. you may change the label of the second I0 from "-" to "variable". After doing so you get the solution you are looking for.
BTW, I wonder why you are using symbolics while you are just after numeric results. You may consider using Primes numerical methods like "root" or a "solve block". They are more rebust wrt labelling and can deal much better with units.
One way to prevent such annoying situations is by changing the appearance of each of the 7 possible 'labels' such that they are readily distinguishable.
By default 'automatic' and 'variable' use exactly the same font, colour, and size. The same is true for 'system' and 'keyword', and their difference to 'function' isn't particularly obvious.
You might consider changing the colour of 'automatic' to orange, so that it sticks out.
While you're at it: Note that 'unit' is blue and italic, it should be upright (roman) style according to international standards...
As far as I know you can't change the color of "automatic' but if you have a different appearance of all six possibilities you can easily see if the automatic had chosen the wrong choice.
Check this,
and the Prime4 file attached.
I guess you just colored that single variable. As you can see in Pic1 in the expression x=y+z the y is labelled "-" meaning "auto" and still is colored black (because auto labelling thinks its a variable and variables are black).
Pic2 shows that I only can change the display of the six types listed, not for "auto".
P.S.: I am not allowed to embed pictures in posts as I get the error that I reached my limit of 1000 pictures!? Not sur what will happen to my answers in the various threads if I delete the pictures which were automatically collected in "My Photos".
Fortunately I can still attach pictures.
Yes, I did.
I see what you mean. So Variable's would have to be coloured, rather than Automatic's...
No that doesn't work either.
Here's what happens if I create a new set, and label appropriately:
The upright (roman) style of Unit is kept. The rest of my changes is just forgotten.
Considering Prime, Mathcad was way ahead of its time...
or
Prime is just a (too big) step backwards. But we know that for some time now.
You have to set the new style via Menu: "Math Formatting" - "Label styles" as shown in one of the pictures in my other post. This seems to work. Unlike as in real Mathcad changing the style simply in one expression does not affect all the other expressions of equal style. Thats a small improvement in Prime IMHO.
or
Fully agreed on.
P.S.: I just tried deleting one of the pics in my "gallery" of 1000 pictures and as expected this damages the post it originally belonged to (my first answer in this thread here). The pic is replaced by a huge dummy pic. So deleting the pics in my gallery so that I would be allowed to embed pictures again is not a solution as it would render my previous answers useless. A ridiculous situation - hope Jaime Lee or a mod will come up with a suitable solution for this soon.
Obviously, PTC maintains a maximum threshold of helpfulness which the corporation endorses. You've apparently reached that threshold, the community loves you for it, but PTC has capped your further dissemination of insight in the same vein as the 15 to Prime transition has unfolded.
Anyhow, from my experience your not going to get any traction from PTC so I would recommend just creating a new account if you intend to side step their apparent cultural quirks...
As a side note, in the video game world when one beats a game and goes in for another round, the player often gets some emblem on their avatar and is henceforth regarded to as possessing the first level of "prestige"... I think you've done this in the PTC community good Sir... ![]()
https://support.activision.com/articles/en_US/FAQ/Prestige-in-Call-of-Duty-WWII
Werner has joined the ranks of a select few:
Kudos, Werner!
No, this time PTC seems to be guiltless. As I understand it the 1000 pictures limit is/was a default limit in the Lithium forum software. The problem seems to be that we don't use the community the way Lithium had designed its software (we could also say that PTC had chosen the wrong software, though 😉
Most of us see it as a user driven support forum and could happily do without all of its "social media features".
The image gallery is meant to collect and post photos the way people do on the various well know social media platforms. For this way of use, a limit of 1000 may make sense and it would not hurt to delete older pics to make room for new ones. If I would delete pics, this would make my older answers useless in most cases.
The design of this platform did not consider that a picture embedded in a posted text might just be a small screenshot whose purpose is not show-off or fun but to clarify a given answer.
But the problem is fixed for now. Our community manager Jaime Lee requested by Lithium to increase the limit and now the limit is 3000, which should be enough for the next few years, I think.
It sounds promising Sir however, the image you so graciously provided me remains replaced with a dud... Additionally it would be prudent for the forum vendor, Lithium, to provide a warning to users who are deleting pictures that their posts will consequently break.
Anywho, thanks again Sir...
I agree that a warning and information concerning that limit would have been beneficial.
BTW, it looks like the limit only does apply to picture which are embedded, not to pictures which are attached to a post.
I deleted that picture in my answer here as a test because it was in no way essential to the answer (I had also attached the Prime worksheet) and I already suspected that deleting that picture in the "gallery" would affect the post. I had not saved that picture so I would not be able to upload it again. Deleting the dummy picture would be possible but it would make people who read this thread clueless as to what I am talking about.
So I guess its the best solution to leave it as it is.
Acknowledged...
Mathcad Prime provokes a good deal of questions on my behalf. I struggle to make worksheets that flow from some givens at the top to a solution at the bottom. I'm having to solve things manually, or copy and past return values and starting over. Then it circles some values in red, and it thinks my variables are units, neither "feature" you can turn off from my understanding. So anyway, I'm glad they facilitated your further participation because my questions are mounting...
@Hum wrote:
Acknowledged...
My participation here never was at risk. It was simply that I wasn't able to embed pics in my posts (I still could attach them) which was a bit annoying. The reason I mentioned this subject here simply was because I had chosen a pic from this post for testwise deletion. Guess it would have been a better idea to save the pic first, delete it and then re-add it again.
Concerning your Prime problems - feel free to ask here but give a new question a new thread. There a quite a lot of people out here capable and willing to help you.
