Will not pull values from array
gparaiso
Hi, for some odd reason Mathcad 15 is not pulling from the "enx array" despite that array having values in these indicies.  Is it because the derivative? Anyway I can fix this?
(To:gparaiso)
You should post the worksheet, if possible.
RichardJ
(To:gparaiso)
It has nothing to do with the derivative.
It's hard to debug a picture, so please post a worksheet. Making a wild guess, what is the value of N, and how many rows does enx have?
What happens if the condition:
is not met?
If it is in any case from 0 to N-1 then the individual element will default to a 0 result:
If , however , it is the last element, then the array will be 1 entry short:
As the next calculation is looking for enx[N which does not exist, Mathcad reports an error.
Regards
Andy
