Working issue
sattila
Working issue
Dear!
When I try to open the uploaded mathcad file I got this messeage: An attempt was made to access an unnamed file past its end. I don't know that could be the problem since I don't changed anything in the file from last time I worked on It and It didn't chrased or something. Please help me cause I had a 3 days 0-24 work in It and I don't have enough time to start It from 0!
Thanks before: Attila
5 REPLIES 5
VladimirN
(To:sattila)
Please find your edited worksheet for Mathcad 11, 14/15 version (and also in PDF) here: Edited worksheet "Rácsos tartó számítása2" (MC11, 14-15, PDF) for Sotus Attila
Dear Vladimir,
I get the same message:  An attempt was made to access an unnamed file past its end
Can you explain how you solved the issue in the worksheet above?
VladimirN
(To:sattila)
Hi Agnes,
I opened the document, agreed with the warning window (by clicking "Ok") and re-save the document in different formats - ".mcd" and ".xmcd".
Please start new discussion in Mathcad community if you need some help, here:
https://www.ptcusercommunity.com/discussion/create!input.jspa?containerType=14&containerID=2003
PTC Mathcad
Thanks!
VladimirN
(To:sattila)
You're welcome.
