Wrong Value
BB_14100646
Wrong Value
In my attached program, I'm getting the wrong value.
The A value should calculate 6.01 mm...
However, MathCAD 9.0.0.0 calculates 15.77 mm
I double checked my numbers and ran them through a calculator and I got 6.0086. I presume I have the wrong units somewhere, but I can't figure it out. I attached my program for review, or you can look at the screen capture of the calculations below.
     Brent
(To:BB_14100646)
You forgot to specify unit degree when you wrote 90. So it was interpreted as 90 radiants which is about 5160 degrees.
(To:BB_14100646)
Perfect! Thank you!!
