I just purchased and licensed Mathcad Prime 7.0.0 and want to check that it correctly converts the XCMD files we create with Mathcad 15. The PTC 'Migration Guide' says: "To start the XMCD, MCD Converter ... click 'XMCD, MCD Converter". When I do this, it says to install XMCD, MCD Converter using 'setup'. It also says "Alternatively, you can start it from the Start menu".
But, I can't find either .'setup' or the Start menu. Please advise.
That's weird. I can even start the converter interface from the free Prime Express.
But then it tells me I have no license (to actually start a conversion).
Are you sure you've installed Prime 7 properly?
Does it 'function', entering and evaluating expressions?
See this item on issues regarding installation and related topics:
@RB_2196962 wrote:
...it says to install XMCD, MCD Converter using 'setup'. It also says "Alternatively, you can start it from the Start menu"...
Can you provide a screenshot of this error?
