adaptive quadrature using Mathcad programs Simpson and adapt.xmcd
Joeboy
I need someone to explain to me how adapt works, seems like it should go into an endless loop if I-I2 never gets less than tolernce value.
Fred_Kohlhepp
23-Emerald I
(To:Joeboy)
Each time the Adapt(f,a,b) function does not return an answer within tolerance it subdivides the interval and applies itself to each half.  This process continues (reoccurs) until the desired criteria are met.  So a process mght look like:
        fail
                              fail        fail
          fail                              pass                              fail                              fail
pass               pass                                             fail               pass          pass     pass
        pass     pass
The answer would come back as the sum of the passes.
Joeboy
(To:Joeboy)
Thank you for the help Fred.  How does the program exit the loop ? Is there a maximum number of passes it can make ?
Fred_Kohlhepp
23-Emerald I
(To:Joeboy)
The idea of recursion is that the program will call itself over and over, as many times as it needs to.  So each time the test of criteria are not met two more instances of the program are launched.
When the criteria are met, the answer (correct to the specified accuracy) is retruned. In the small example above, fifteen different cases of Adapt were launched.
Joeboy
(To:Joeboy)
Fred, I don't see the small example you refer to
Fred_Kohlhepp
23-Emerald I
(To:Joeboy)
The first comment:
        fail
                              fail        fail
          fail                              pass                              fail                              fail
        pass     pass
(Might make this a discussion rather than a document--it's easier to see revisions/ comments.)
