convert xmcd to prime 8
AC_10558601
3-Newcomer
hello again! Can someone convert my XMCD files to prime 8, please. My Mathcad Prime 8 doesn't have the option to convert it even though I tried to reinstall it.
(To:AC_10558601)
Did you check the option to install the converter when you (re)installed Prime? Its unchecked by default.
Find attached the two files converted for Prime 6. You should be able to open them with P8
(To:AC_10558601)
Yes, I checked and for some reason it's not there. It's annoying. Thank you a lot for the files!
(To:AC_10558601)
You might consider contacting PTC support about the missing converter.
