corrupted file as I add an image from paint
asinuani
hello,
my name is Assaf and I'm a new user of mathcad.
I've noticed that if I add an image to a mathcad 14 file, as I reopen the file it is corrupted, see at the end of the attached file.
did anyone encouter such a problem?
note:
I'm adding the image with Ctrl+C Ctrl+V
RichardJ
(To:asinuani)
What happens if you go to "Paste special" and paste as a bitmap?
And please don't post the same question twice.
VladimirN
(To:asinuani)
Hi Assaf,
I opened your file without any problems in Mathcad 15 M045 version. In attachment you can find resaved Mathcad worksheet and PDF file with contents of the worksheets after opening.
RichardJ
(To:VladimirN)
Just no visible problems. There are images in there, but they are transparent
Hi Vladimir,
I've made a mistake and the file you are looking on is the wrong one.
please notice that the problem is in file "Flugas 20151223" instead of "Flugas 20151123".
The problem is at the end of the document.
