differentiate contour plot overlay
Efried
7-Bedrock
I do want to overlay two efficiency maps. I is possible to have different lines for the contours - one solid - one dashed?
Now I'm using Mathcad 15 but may be that is possible with Prime?
many thanks
Doh! "Special" tab, Line Style on the right hand side - solid, dash, dotted, dash-dotted.
Stuart
7 REPLIES 7
StuartBruff
23-Emerald V
(To:Efried)
many thanks
I don't see an option to select the line type, but you can change line thickness and colour; you can even choose to have one displayed as a solid colour and the other as a colormap (eg, greyscale).
It may be possible to get a dash-like effect by defining your own colormap that alternates between, say, white and black or between light gray and black.
Stuart
Stuart
perfect answer - thanks a lot - also the artwork is great.
Now I'm hopping to the next problem - is there a possibility to have a colour scale legend added, so we can see for what numbers the colours of the lines in "colour scheme mode" stand?
thanks
thanks
It is a built-in tool in Mathcad Prime 2.0.
But we can do it inold Mathcad by using an add counter plot:
http://twt.mpei.ac.ru/MCS/Worksheets/TMO/Pde-Temperature.xmcd
Well done, but IMHO a "normal" worksheet which can be opened and examined locally would be more helpful though.
WE
Efried
7-Bedrock
(To:Werner_E)
That variant is cumbersome with regards to the position of the labels...
Mathcad 15 or mathcad Prime?
I can do it thru plotting an add plot f(x ,y)=const
